FS: sideart for multicade
sprimack
Arizona
Rating - 0%
0   0   0
I have an extra set of sideart for a multicade or for whatever else you want to use it for. I can have more made if there is any interest in it. This was done at a professional print shop on adhesive vinyl. The picture is not great- that line on the upper left side is not on the sticker) The measurements are 20 inches by 36 inches. The cost is $80 shipped anywhere in U.S.
This is two pieces (IE. two sides), correct? Does it have the typical protective layer on-top so the artwork is protected from moisture, smearing, etc. (I am assuming, but want to be sure)?
Scott C.
Scott,
Yes it is two identical pieces. Each piece(sticker) is 20"x36". I don't know if its been laminated if that is what you are asking but I had it done at a local print shop and I told them I want it to last. I think it might be done with "uv" inks? It definately will not smear-
Ok I just sprayed windex on it let sit there for ten seconds and it was fine. If you don't like it send it back unused and I will refund your money minus the shipping charges.
I am checking with the printshop to see if it was laminated but it definately does not need spray adhesive-- It is printed on an adhesive vinyl. All you do is peel off the back and stick it on.
I have one set that is extra because I had a min. order that I had to put in and as of right now its still for sale but if there is an interest in it I can have more printed.
