FS: ROWE AMI MM5 Jukebox
RJ
Donor 2012
Illinois
I picked up a1971 ROWE AMI MM5 Presidential Line New Orleans juke box in a bulk buy. All the parts appear to be there. None of the Vacum tubes are missing. The cabinet is in great shape, a little dirty from storage. I have the front door and the coin box key. I turned the juke on and it lights up and the platter spins. I could not get it to scan. I was able to put it in service mode and credit up. I can select a record and the buittons stay in and a gear starts to spin in the front, but the carousal dosnot spin. The belt on the carousal is still intac.
I am asking $150.00 obo, pick up only. Has most of the 45's installed if not all.
The Jukebox is located in Burr Ridge, IL. Hwy 83 and the cal sag.
I will try to post some pics later on today.
RJ
Pictures of Juke
I took some time yesterday and actualy got the JukeBox to work.
I still needs a few tweeks
With that said, it will select and play the records. I have it in the service mode so I do not need to coin it up. I am able to scan and the Carousal matches the play letter and number that is displayed. The sound is pretty good for an older juke with a Tube amp, I had forgoten how good tube audio amps sound.
Allways open to trades..............
RJ
Juke
Hello RJ,
The 1971 Rowe Ami MM-5 you have for sale is the Presidential Line New Orleans.
Regards
Alan Hood
ami-man
UK
Thanks for the info. Its a good sounding JukeBox. I have allways enjoyed the sound of a Tube amp versis a Transistor amp. Richer smoother sound.
RJ
