Phetishboy
New vinyl, new side art. Original marquee, bezel and CPO. Marquee and bezel are physically perfect, no flaking, but they do have fading in the red inks, as is typical with these machines. The original CPO would be perfect if not for 2 small holes and a small ding that were put there by the previous owner. The holes had bolts in them when I got the machines, and I took the bolts out. The ding is in the front by one of the security screw heads, (all of which I had painted). The holes are small and aren't really a big deal, but I know how picky some of you can be. The big 3-sided CP 'apron' was powder coated as were the marquee brackets and the coin door. Cab is basically flawless. Had the Sounds Good board recently serviced, sound seems to work great now. Original 4900 monitor is clean and recapped, it has slight Rampage burn that is not noticeable when the game is on, and really not noticeable when it's off, as I added an official Midway Tinted plexi to the Midway bezel, complete with the clips. I will ship thru NAVL or similar from zip 56310, if you set it up. $1000 or B/O.
