FS: R-Type II PCB, Sideart, manual
Franklin
Caledonia, Wisconsin
For Sale: A working R-type II Jamma PCB, Owner's Manual and set of NOS (16"x20") Sideart (Conversion?).
Asking $60/shipped obo.
Larry C.
Franklin, WI
R-Type I is JAMMA so I believe R-Type II would work unless R-Type had two different board types.
Says on KLOV game list:
Strange, that while the PCB for RType says JAMMA on it, it is not a game that can be simply swapped with another JAMMA board. This game has no 5V pinout on the edge connector, nor does it have the test and tilt pinouts of a true JAMMA connector. Also, nowhere in the manual is the word JAMMA mentioned.
So, maybe it wouldn't work...
So it appears that the cabinet wiring in R-Type isn't sufficient for R-Type II. However, you CAN run the original R-Type in a JAMMA cabinet. It appears vice-versa isn't possible without some additional wiring. I'm also not familiar with the power supply on the R-Type cabinet.
