FS: Pole Position PCB set-monitor chassis-monitors
SuperBee4406
greenville, South Carolina
I have a few items for sale - Shipping not included
1. Pole Position I PCB set - semi works. Boots and plays, but has alot graphical glitches showing. Edges have typical burn. I tested the boards, by running power directly to boards using the test points. $75
2. AR II -01 out of a pole position. I have two. Was saving them for backup, but decided to sell them. Working. Both very clean. $25 each
3. Chassis, WG K7000A 19" - Working and capped. $65
4. VGA monitors. These came out of some game that looked like a slot machine. They are tubes mounted in frames and not stripped computer monitors. Perfect for a mame machine. 20" tubes. Some slight burn from the slot machine game, but they still look good. I have two. $50 each. I think I am doing to do local pickup on these for now, may change mind.
5. Coin Door - out of a Asteroids Deluxe. No coin mechs, or lock. $20
6. Coin Door - 3 slot. Out of Rampage. Coin mechs included. lock with no key. $20
