Moomert1
Well, I no longer have any use for this. Includes everything seen in the pictures. The Everdrive is already loaded with Domestic and Import games. Please note, the CD games you see, are all reproductions. The legit items, besides the system are as follows:
Alien Crush (Hu Card)
Arcade Card
Splatterhouse (Import Hu Card)
and the
Tennoke Bank.
There are issues with the CD Drive. Hu Cards work perfect. I sent it in for repair on the CD drive and this is what I was told.
"The issue was with the main large drive gear for the lens motor.
Basically all RX systems have this kind of gear and some R systems do as well. This gear in particular is made in two parts with a ring spring of sorts that applies pressure to hold them tight together. Overtime this tension ring wears out and the gears just starts to spin in the center which won't move the lens.
The fix is to simply remove the tension ring and just Glue both parts of the gear together. Basically it makes it just the gears inside Black DUO systems that ar just one piece instead of two.
All works good now."
The fix did initially work. Now, its very difficult to get the CD Drive fully working again. I am assuming the fix unglued itself.
This does play Domestic and Import Hu Cards. There is a switch which you flip back and forth depending on which Hu Card you want to play.
How about $400 shipped obo?
Arcade Card
and the
Tennoke Bank.
