FS: Pacman & Ms Pacman harnesses & Transformer assemblies $20
Todd Tuckey
Donor 2019
Southampton, Pennsylvania
I have 2 complete Pacman and 4 Ms Pacman complete bottom trasnformer panels with full ahrnesses, working fine when removed, and unhacked except where I cut the top light and on off switch wires (you can easily reconnect)...this is ideal if you have an edge connector hacked or burned, or a bad transformer on the bottom....They are $20 each....shipping for one is $15 and two $20...let me know! direct email fastest way and can ship immediately tntquality @aol.com Picture shows what you will get---similar to that. Todd Tuckey
as the post explains, the test switches are inside the cabinet on Pacman, but on the coin door for Ms Pacman...so COIN DOOR WIRING PLUG IS LARGER than on a Pacman (also Ms Pac has coin lights, and harness adds the wiring from the transformer.)
You CAN interchange these with just an easy change on the coin door wiring...the game wiring, sound and poicture are all identical as with the transformers. Todd
