kuglerarcade
hi this is my ad on e-bay SINBAD GOTTLIEB PINBALL MACHINE in good shape that i started to restore and is a some what working project that need finished.im listing it for less than i have in it.it has a new ni-wumf cpu instaled as well a a rotten dog new driver board and a power supply.it also has had a new driver to cpu wire harness installed.i also repined many plugs a1j1,a1j2,a1j3,a1j6,a1j7 and finally a2j1.the playing field and crome has been cleaned and waxed as well as a new rubber kits and bad playing field bulbs replaced.the legs have been repainted with the hammered finished .now for the problems1st problem display fuse blows when game is powered on dont know why.the game can use a new set of plastic.there maybe other things wrong i just stoped after the display problem.the backglass HAS HAD SOME flacking it has been thripled thicked so it will not peel in the bad spots any more.i used a permant marker to some what color the red to make it match some what you can see in pics.the game also has a new coin door lock and backbox lock.it has a coin box and i will find 2 coin mechs you may need to change the pins to fit.i will give you the old boards
