FS Off-Topic: Flood Lights and Fluorescent Bulbs/Ballasts
TheDrewster
Donor 2012
Reno, Nevada
I purchased a bulk lot of bulbs from the local Borders that was closing. Yeah, that was stupid. I have hundreds of PAR30 and PL-L Bulbs that I would like to sell, and will let them go for a good deal. If anyone has a use for any of these bulbs, make me an offer. I just want to get rid of them, as you can see, theyre kinda blocking my games!
Bulbs:
49x Phillips pl-l 18w 35 4 pin 1200lumen 2g11
23x Phillips 50par30L fl25 120v 590lumen
18x Phillips 60par30S wfl40 130v 610-800lumen
56x Sylvania 75w par30 1130lumen
24x Phillips pl-l 36w/835/4p
25x Philips 75par30L nfl30 130v 940lumen
24x Philips pl-l 40w 835 4p is
72x Philips 50par20 fl25 120v
10x GE 175w mvr175/sp30/u
30x Philips plc/26w/835/4p
29x Philips plc 26w 35 4p
52x Philips plc 13w 835 4p
6x GE cg301d14-gt
5x GE cgx301d16
3x GE c340si277rh
1x GE f26dbx spx35 4p
Ballasts:
5x Smartmate icf2s26h1ldk Ballast
49x GE c213unvbes 0gei Ballast
8x advance icn3ttp40sc Ballast
these:
advance icn3ttp40sc are to work with three lamps...
heres info on the ge ones, looks like one runs several non ballasted clfs like the 12 volt cl-l type .. http://www.lightingsupply.com/C213UNVME.aspx?gclid=CLePg-H3zasCFcECQAoduFv4Sg
heres info on the smartmate ones also meant to run the cl-l lamps i believe.
http://www.atlantalightbulbs.com/ecart/nw012104/ADVANCEICF2S26H1LDK.htm
unfortunately, i need some 277volt ones for a two 8' lamp setup, we have thousands of those lights at our work and the frickin ballasts are starting to show thier age.
the 56x sylvania par30s make nice regular flood lights...
http://www.google.com/#q=Sylvania+7....,cf.osb&fp=faeee247c9964d77&biw=1280&bih=603
the 73x philips 50par20, theres some good in the house cheap resessed lighting lamps.
http://www.google.com/#sclient=psy-....,cf.osb&fp=faeee247c9964d77&biw=1280&bih=603
all the pl-l and plc stuff, i wonder wtf it was used on?? its a shame, seems like lighing you could hide behind trim etc and get that cool backlit look on stuff. good accent lighting...
