HudsonArcade
Just dug out the adapter boards to convert a Nintendo "little connector harness" w/ all the .1" connectors to an edge connector harness to make PCB swapping easier.
Note that you'll need a "rainbow cable" to power the video board if you switch from the little connectors to the edge connectors -- I can make those for an additional $5.
Unlike some other "competing" products, mine has all 3 power connectors (7/9/10 pin) so you won't need to worry about running too much current through a single cable, and it's got the "sub" connector for the 2nd player, so it'll work in cocktail cabinets as well.
