ballytablewiz
FS : Nintendo Coin Door, Asahi Seiko 730-A Coin Mechs
Nintendo Coin Door : Fasteners included. Of those, 2 are replacements in same style but larger, rest are original Ninty bolts, all painted black (heh, at least they're not rusty I guess). Sticker or tape residue on front and harness adhesive remains on back, so needs Goo-Gone or sand and paint. There is some pry damage on the inside side panel of the door, basically some small dents and bends - noticeable only when open, fully concealed when closed - see attached pics for detail. You could probably hammer it flat again easily if you're that anal. Nonetheless, the door mounts flat and straight, still absolutely usable.
> SOLDSKI <
Asahi Seiko Coin Mechs (2) : Model 730-A, used on DKJR, Popeye, Mario Bros, Ninty cocktails, and others. Both fully functional BUT one's microswitch is missing the tiny metal actuator arm, the other is complete. I hooked them both up to my cab and coined up via the slot on the one and by manually triggering the microswitch on the other, so the switch is technically good if you have or make a armature for it. Faceplates have typical sticker residue. Pics attached in following post.
> SOLDENHEIMER <
Local pickup in Mpls. MN is also available and encouraged to eliminate shipping for you. As to why the coin mechs are priced as a set, it comes down to shipping - it's $8 to send ONE or $10.70 Flat Rate for BOTH, so one is pretty senseless.
I'm a very old school man, with no GayPal, and I'm not setting up an account and letting those bastages at another account of mine. Thus, you will have to send me a Money Order (personal check would just add to your already agonizing wait) or pay cash via local pickup and save all kinds of hullabaloo.
> SOLDSKI <
> SOLDENHEIMER <
