WETHEREDS
Working ALL-IN-ONE Multi-Williams set-up with everything located on one Williams mounting plate with a complete Control Panel .
Easy Set-up - mount the plate into your Williams cabinet, connect the control panel, put the side art on, attach the monitor and PLAY!
You get:
1. Working Williams CPU, ROM and Sound Board
2. Clay's Multi-Williams Kit installed and working
3. Switching Power Supply with fused outputs & will include a spare PSU
4. Speaker with audio level control and mounted switches to access set-up menu
5. Complete wired up and connected CP with a Phoenix Arcade CPO.
6. Two pieces of Multi-Williams Side Art - unused with the protective covering
$400
Will ship to lower 48 in U.S. ONLY and I will ship two boxes. The mounting plate with boards attached with be wrapped and double boxed. The Control Panel will be in a seperate box.
You get:
$400
