FS: Mini Cabinet DFW $100
cointech
Donor 3 years: 2018-2019, 2024
Arlington, Texas
I am not sure what this was original but it was a choplifter most recently.
cabinet is in pretty good shape. One spot on the bottom side has the woodgrain laminet
chipped but the cabinet is good. Has coin door, back door, switching ppower supply, iso,
sega wire harness, speaker, monitor glass, marquee brackets, GO7 monitor tube only with frame. 19 inch Monitor is mounted horizontal with light centipede/choplifter burn.
Cabinet is 61 inches tall, 22 inches wide across the front and 29 1/2 inches deep along the side. This might make a nice multi?
Local pick up in Arlington, Texas is prefered but shipping can be arranged to Houston, Austin, San Antonio and local areas by Noel and we can uses freight service for about $100-300 depending on distance and delivery needs.
Eric
Cointech
