FS: Jurassic Park Pinball - $1100 US/WV
shardian
Culloden, West Virginia
I got this in completely dead, real bad shape. The boards have all been professionally serviced. The game plays great now. Everything works. New raptor coil, new ball launch coil, I also have a ring kit, new bulb condoms, new coin boxand a few other odds and ends for a shop/restore that I'm just not going to do now.
The playfield is in excellent condition. The small wireform ramp that feeds the right inlane from the VUK is not original. There is some other wireform in there that I had to modify to fit a little better. I have it ziptied in place, and it works perfectly fine. Honestly, it would be better to have a welder add some mounting feet and attach it to the main ramp.
The cabinet needs work. I tore off all the damage on the low front and planned to fill it even then attach a piece of 1/4" plywood that brings it out even. It will fix nicely and easily there. Other than that, the rails/lockdown bar and stuff need sanded repainted - pretty standard stuff for DE pins.
The dinosaur works great, including left/right movement.
NOTE: pics are from when I was working on the front and had everything stripped off. It is all back on after I repaired the start button mount.
attachment.php
attachment.php
attachment.php
attachment.php
bump again.
If someone is interested but wants it restored, I'm willing to do that. Of course the price would be higher depending on how much work you'd want done. Still, I'd rather cut my ties now to save time for other projects.
