FS: JROK Multiwilliams PCB
Malice95
Howell, New Jersey
*** Traded *** no longer available.
Brand New never used Jrok Multiwilliams PCB.
$300 shipped via Priority mail to the 48 US states.
Or I would take an even trade for a 100% working/tested Black Widow, Tempest, or Juno First Boardsets
MW Artwork also available on my website.
I have a multi Williams kit installed that may be hosed in a Robotron cab. How would use thus in place or with? Sorry to hijack. Hope the bump helps!
Here is the manual that should help if you want to put the Jrok in a cab with an original board set.
http://jrok.com/hardware/wsf/sys_fpga_guide_v11.pdf
You should be able to remove the hosed multi kit and replace it with the Jrok.
You might need to make a couple adapter harnesses.
James(jrok)could help better with the hookup,pm him if you have any questions about hook up.
You could also start another thread in the repair section,there are lots of guys who would be able to help you.
It depends on what MW kit you have.. If its a big boardset.. its probably Clays original kit. This boardset is tiny and is jamma only. Maybe 6"x6".
Most just rewire the cab to be jamma or use and adpater and run Jrok's boards these days.
