Liteyear98
Up for sale is one JAMMA test rig mounted in a plywood case
Items built in:
SAMTRON 6" monitor
Switching Power Supply
CGA to VGA Converter Board
New JAMMA Harness
Small Converter board -- See the details here:
See the video here:
Asking 200 plus shipping
You can see the built converter that is used on the monitor.
Pic 1 - Samtron Monitor and Two built converter
Pic 2 - Close up of RGB into Chassis
Pic 3 - Converter Assembly (JAMMA Video in, then Converted, then to the Chassis)
Pic 4 - Video in from Harness and +5 Volts for Converter Card
Pic 5 - OutPut from Converter Card (RGB from White Molex Connector to IC103 on Chassis and Separated H&V Sync, Contrast and Video Ground to ten pic connector on Chassis)
(Higher Res pics here)
Items built in:
SAMTRON 6" monitor
New JAMMA Harness
See the video here:
