FS Game: FS: JAMMA Sega Genesis
robivy64
Prattville, Alabama
Hey guys,
I have a JAMMA compatible Sega Genesis for sale. This is a 1 player version, and is fully JAMMA compatible.
The RGB output has been increased to 1V, which is native for arcade monitors. No monitor brightness adjustments needed on my Astro City! This system runs on the +5V power source.
Looking for $150 shipped within the US.
These systems are great. I had one and absolutely loved it. It you are a Sega Genesis fan this is great to have in your collection.
I have a couple questions because I have not seen this before. Do you also make a 2 player version? How many buttons does it support? Can you hook up sega cd, 32x, etc to it and use in cab?
any chance you could help me mod the one I got from Melissa to display properly on arcade monitors like this one does? Mine is dark and when you adjust monitor brightness up high it shows raster lines...
Yes, I can upgrade this unit to a 2-player version. This supports ABC + Start. Sega CD can be used, and I can even wire up a power "tail" that makes the entire thing run from the JAMMA harness. 32X = No.
I've had a few PMs abut compatibility with certain cabs.
This will work in any JAMMA-compatible cabinet. Operates like any JAMMA arcade PCB.
