Arcade1VA
O.K., I have these two sitdown games I would like to sell as a pair. Both are working and will play as stand-alone units. The Indy is wired with a service button so you can go into test mode to calibrate or change the settings. It will need an on/off button wired as it does not have one. The Daytona has everything wired including the on/off and test/service as well as a volume knob. The monitor gets a bit squirrly at times as far as the colors needing adjusting, as you can see there is a bit too much blue in the pic. I have the adapter pigtail for the shifter (bought from Happ) that needs installed. The large leader marquee goes to the Indy, and is included. $700 O.B.O. for both. They are located 20 minutes south of Roanoke, VA. Pickup only, so bring a trailer (they are on wheels). Paypal only if you pay the fees, or cash & carry. PM with serious inqueries please.
