FS in NJ: SNK Playmore Hanaho bartop cabinet - perfect 13" CRT, use as Jamma test rig
Emdkay
Donor 7 years: 2011, 2015-2020
Whippany, New Jersey
Rating - 92.9%
13   1   0
SOLD!
I have an extra SNK Playmore Hanaho bartop cabinet and don't have any use for it. Asking price is $250. I'd prefer a local pickup in Springfield, NJ. Shipping will be an option only if there is first no interest locally.
[+] The 13" CRT is flawless with absolutely zero burn-in.
[+] The insides appear perfectly clean.
[+] Mono speaker puts out sound, and all buttons registered properly to the jamma harness.
[+] Cabinet manufacture date is 2005 according to the original PCB.
[-] The original PCB has been removed and is not included.
[-] The control panel has obviously seen better days with the left-side t-molding missing, control panel artwork gone, and some chipping.
These are really nice cabinets; easy to mess around with. Use it as your jamma test rig, or easily restore it with some new 1/2" t-molding, control panel artwork, jamma board, and power supply.
The cabinet has a standard jamma harness, so toss in whichever PCB you want. You'd just need to tap in a stronger power supply (like the WEI-YA 15AMP arcade switching power supply), as the power currently in the cabinet is only enough juice to run the original Hanaho PCB.
Only the cabinet pictured on the right is for sale:
These are not 100% jamma compatible. I cant rember what it was missing on the voltage hookups off the top of my head.
Yea.. on one that I own (not the one for sale) I had to tap in 15AMP power supply to give it the extra power to run a jamma board. However gets this cabinet will need to add their own power supply, depending on what they do with it.
If you part this thing, I'm really interested in the monitor bezel. I would also consider the tube and chassis board.
I don't need the entire unit since I have one that got damaged by UPS.
The size and weight (55 pounds) of this cabinet makes it a little too much of a hassle & risk to ship. I'd rather have a quick local sale, so I'm offering this for $150 firm. Local pickup in Springfield NJ.
Not to hi-jack, but do you know of a "how to" on adding the power supply?
I have that same taito mini and need to do that to run other boards.
Thanks (free bump) :)
I'll be in nj next week working and if I'm close to you I'll gladly pay 150$ would be kool to have this in hotel rooms to give me something to do
I took some pictures when I did this. I'll try to remember to gather them up and show you. If I forget, please PM me :)
