GuSH
$75 shipped. I hooked it up to the monitors I have and you can see it working but I can not get a monitor to sync to it I don't have the correct resolution. It is packed and ready to ship out.
The green board was the one that launched with the Fore series, it used a regular power supply hooked in through the jamma connector. They found out after a while that this really taxed the connector because it sent a large amount of power through the board to power up the hard drive, which was hooked to the board. So later they sent out a little "Y" cable to allow you to power the green board through the 4 pin connector next to where the IDE cable plugs in, and plug the other 4 pin connector into the Hard Drive (eliminating the power connectors on the card edge).
Later, they revised it again and made a 'red' board that you can just plug a computer type ATX power supply (has to be beefy, though) into.
So basically the difference is, the Red board takes a different power supply and is 'newer' than the green board. Both of them seem to be pretty reliable.
