FS/FT - Rock-ola Warp Warp Project Cab or Parts - San Francisco, CA/Bay Area
I've got a Rock-o-la Cab available, it's a former WARP WARP.
The cab was converted to Jamma and has a switcher wired in. Cabinet works as it stands. Has original Toei? monitor that works. More than likely needs a cap kit or adjustment as the image is a bit skewed and has some curl. I have not touched it though.
The bad is...the cabinet I think was stored "face" down at some point and the face of the front panel has major swelling and surface bubbles. The top of the cab also has seen moisture and has some sag. Interestingly enough the sides, the bottom of the cab, even the entire insides are solid. And even the face with the moisture damage is not compromised - the inside/opposite side of the wood is solid.
But make no mistake - it's a project for sure. I don't think I have it in me to take it on after getting it home.
Would be willing to entertain a trade offer (not sure what I'm after) or $200 takes it.
Got plenty more pics and will get you any more you may want/need.
