The one with the pushbutton, is that the one that they used to put in Dynamo HS-5 cabs. They mounted/bolted up in the middle of the back of the cab and the pushbutton was on the side of the cab. If so, I wouldn't mind having a couple of those if you get more and those are the ones that cab uses.
