dweebs0r
FS/FT: New in box 19" Betson Imperial arcade CRT Monitor (US-Memphis, TN) ** SOLD **
FS/FT: New in box 19" Betson Imperial arcade CRT Monitor (US-Memphis, TN0
I bought this for a project and I dont think I will be needing it. This is brand new in the box and still has the plastic on the screen.
$150 if picked up. $200 shipped.
Thanks,
-D
Details (from website):
IMP - 19" CGA MONITOR NO ISO REQ
Specifications
Safety Approval: C-UL, DHHS, TUV
Screen Size: 19"
Resolution: 480x240 pixels
Type: CGA
Luminance: Adjustable with user control
Video Bandwidth (-3dB): 12 mhz MHz
Video Input Connector: Molex, 6 pins
Video Signal: RGB Analog Positive IV_5VP.P
White Balance: x=281 +/- 20 y=311+/- 20
Horizontal:
Non-Linearity: 5 max.%
Scan Rate (Min/Typical/Max): 45/60/75 Hz
Sync Polarity: Positive/Negative/Composite
Vertical:
Geometry-Linearity: 5 max.%
Non-Linearity: 5 %%
Sync Polarity: Postive/Negative/Composite Hz
Misconvergence - Center (Typical/Max): 0.5/0.7mm
Misconvergence - Corners (Typical/Max): 1.0/1.4mm
Degaussing: Automatic at power up
Pincushion (All Brightness): 03
Raster Dim Adjust Range - Horizontal (Min/Max): <350 >440mm
Raster Dim Adjust Rnage - Vertical (Min/Max): <185 >340mm
User Adjustable Controls: Luminance
Operating Power Max: 065W
Operating Voltage Min/Max: 100/240V
High Voltage Typical: 0250V
High Voltage Regulation Max: 020V
Operating Temp Max: 10/55 C
Relative Humidity Operating (Min/Max): 10/90
Thanks,
-D
Specifications
Screen Size: 19"
Type: CGA
Horizontal:
Vertical:
Non-Linearity: 5 %%
