FS: Clay's Multijamma x's 2
ArcadeNerd
Pennsylvania
Sold!
Hello, I have acquired 2 of Clay Cowgill's Multijamma sets throughout the past year from here. Both of them were set up and running fine in separate cabinets. I decided to switch (yes, pun intended) things up a bit and no longer need these multijammas
Set #1 = MultiJAMMA Controller version 1 with 5 of the switchboards - $125
- I had this working in a vertical machine with 3 of the switchboards running and never set up a second power supply to hook up the other 2. Because of this I can't vouch for the functionality of running all 5. It worked fine with the 3 boards that I was running though.
Set #2 = MultiJAMMA 8 Controller Revision 1.4 (2008 and newer) with 3 switchboards - $125
- I had this running fine in a different vertical machine with the 3 switchboards provided
I would like to get $125 shipped in the continental US for each set (older board with more switchboards vs newer board with less switchboards) so let me know which you'd like when you PM me. Thanks!
Are there any functional differences between the switchboards? The layout is different, but I am curious if any other issues were resolved?
Either way, free bump for you. :)
Scott C.
