OK,
I have 2 programmers here that I know nothing about. I don't have software for them and I have no way to test them.
Programmer 1: An older Willem EPROM programmer. This is the model with a parallel port and USB port on one side (not opposite sides). The USB appears to only be for power and is the same shape port you'd find on your PC - not the end you'd expect to be on a device.
It has no markings on it except for some silkscreening around the 11 LEDs and a few sockets. This has the 32 pin ZIF socket, 2 32 pin PLCC sockets, and a bunch of machine pin DIP sockets for PICs and I2C EEPROMs.
Programmer 2: A serial port programmer for PICs and I2C EEPROMs. http://www.olimex.com/dev/pic-pg2.html for more info. It comes with the ICSP cable AND with a PIC16F877-20/P chip.
Again, these are untested and I don't have software for them. If I did have software, I wouldn't waste time testing a Willem programmer as I do not like them. If you are an experimenter then here's a cheap couple of programmers.
$10 shipped in the USA for the pair.
