FS Brand new smaller 60-1 pcb $95 shipped
flex
Donor 7 years: 2019-2025
I have 5 of the newer smaller 60-1 pcb's.
2 left bump to the top!!!
I have a question about the new design. Did they make any sound improvements that anyone is aware of ?
I didn't think so. I played gyruss to test, well and congo bongo, and since I have a dedicated congo bongo, it was pretty blatant how bad the sounds were compared to the real thing.
the trackball connector worked fine, which was nice.
Sucky, That doesn't make any sense. You'd think it wouldn't be that complicated to fix. Especially if they did a complete redesign of the board.
knowing china, to cut cost, the company gave the contract to a new factory. I think you guys are fathoming a new generation of this board, when its may just be a diff company.
have two more for sale......
Got mine...works great....
Fast shipping.....Thanks!
Quick question: how does the high score stay updated?
Also, how do I add trackball?
Thanks,
Chris
Hello,
Did switch 3 controls the high score save setting. As far as a trackball, you can use the harness that bob roberts sells and connect it from the trackball to the con3 connector on the pcb. Very easy to hook up, once the trackball is in the control panel. Some older trackballs dont work without the newer optical boards in them. There is a guy on Ebay that sells a new trackball for around $48 that works great. I am sure you can find a harness there too. Thanks for the bump!!!
Sunday bump. If someone wants both, I will do $180 shipped on the pair.
