FS: A bunch of Vid and Pin PCBs
Linolium
Taunton, Massachusetts
I'm thinning the PCB heard a bit:
Pin PCBs - $40 shipped each, or $60 shipped for both
Untested Bally Lamp Driver A5 (AS-2518-23) from Black Jack. Looks clean
Untested Bally Solenoid Driver A3 (AS-2518-22) from Black Jack. Looks clean
4 Untested Bally Display Drivers A1 (AS-2518-21) from Black Jack. $20 shipped each or $60 shipped for all 4 (SALE PENDING)
Video PCBs ($40 Shipped each unless otherwise noted... less if buying multiple)(Take all 6 for $200 shipped.)
Working Soul Edge (Ver.A I think)
Working Wheel'em In PCBs (2 boards connected via ribbon cable)
#1 Working E-Swat boardset (Game Board and System 16B Motherboard)
#2 Working E-Swat boardset (Game Board and System 16B Motherboard)
Working Neck 'n Neck PCB
Working Pac-Man Bootleg NEWPUCK2 + Harness (Was working 3 years ago, haven't tested it since) $50 Shipped
I can PM images on request.
I looked at the numbers in my EK manual and they had diff numbers listed :(
Shouldn't, it's an MPU-17, and those boards work with it.
http://www.pinrepair.com/bally/index1.htm
Scroll down to the GAME LIST, you'll see both those boards will work with your EK.
The lamp driver is only specifically different on MPU-17 for 2 games (Freedom+Mata Hari), the others can use either board. ALL of them use the same Solenoid board.
I think they have about 3 or 4 part numbers but they all work. So EK probably came with a different solenoid board, but it's functionally the same part.
I'm surprised that a Mata Hari lamp board is different too, I've had two or three of them and always just threw a board in it if it was missing. They're all laid out slightly differently but technically work the same from pin to pin.
Yes but Mata Hari uses the 23 board that is far more common over the 14 that only the earlier Freedom needs. Bet all those lamp drivers were 23's.
