Ok, I was right about the Normal vs Wide mode operation. If you apply +5V to pin 8 it will run in a 4:3 aspect ratio with the black bars on the sides. If you do not connect anything to pin 8 it will default to stretched mode. Please see the attached shots of my IIgs screen again. Once I made a real connector so that I can see the Blue background it is more obvious that it was stretched in my original tests.
These are nice little displays.
-VJ
-VJ
After:
Anyone find a decent solution for the missing plugs? Mine is not going to have them...
Yours should have a set of cables attached.
ken
I got mine today, and played around with it tonight. I almost screwed up really bad though. I was building a test harness, and when I cut the connectors on the monitor cable, I cut the wrong side! Instead of cutting by the long connector, I cut the side by the two separate ones. Luckily I had left enough to splice onto anyway.....barely. That"ll teach me to wire something without my music playing.
These little things work great. Once I get my new test rig finished, I post a picture (I'm sure some will find it amusing.)
Next superauctions when they can't even give the crappier pachislos with the LCD's away I know what I'm getting![]()
PS: Thanks to everybody who has sent iTrader responses. I appreciate the feedback.
Please don't forget to leave iTrader feedback on your buyers.![]()
So here's my new portable JAMMA test rig. I still need to make the control panel and pretty it up, but you get the picture. Fully self contained, thanks to this awesome little monitor! (I was gonna use it for a mini machine for the car, but I would have needed two for that project)
|| o
| | side view top open
+-------+ o
| | side view top down
Just curious, Other than Arcade monitors(bench monitor or mini arcades), what else could you use these for (VGA wise) given there limited 480x234 resolution?
