Trackball
I picked up two caberets and I only need one for my project. This PacMan mini cabinet is wired Capcom with a 1942 pcb. The monitor has some pac burn. According to the seller the monitor was just recapped. The monitor is not holding the picture. This is where an optimistic statement comes in. It is most likely a simple sync adjustment. I really did not mess with it. I saw that it worked when it came off the truck and moved it to the side. The cabinet has seen some water on one side at the bottom. I will tilt it over and add a picture in the morning. It has a LED Storm marquee. Backdoor is there and will make a nice multi. You know you want it for a weekend project so come get it!
