mauibarber
Frogger won't coin up unless I use the Easy Coin Up.
I can't figure this out. My Frogger came with an easy coin up "upgrade" and if I push the button I get credits and the credit meter moves. But no matter what confirmation I put the two wires in on the coin switch I can't get it to coin up. I manually pull the metal switch inside the coin mech and I can hear the switch click.
The "Easy coin up" is wired inline with the wires for the coin mech so if it works, putting a coin in should work.
First can anybody tell me the correct wiring of the coin mech on a frogger? I get 3 volts across the white wire and like I said the easy coin up will make it credit so the pcb should be fine, it has no idea what is going on up front just that its getting a credit.
Any ideas of what to look for. I just can't figure it out.
