jimbodeanny
- Joined
- Oct 24, 2004
- Messages
- 4,533
- Reaction score
- 881
Update:
I decided to reflow the solder on the pins for the 3pin, negative sync section of the chassis. Then I recrimped new connectors to the sync wire(s) for the 3pin connector to ensure that there was a good connection getting to the chassis. Still no luck. I was able to briefly get the picture stable, but a little more than a breeze on the h. freq and it would be off again. I also noticed that periodically, there would be a couple tiny black squiggly lines running down the side of the picture. It would only last for a brief moment and then be gone for a bit before returning again.
Also, I tried plugging just the h. neg sync into the chassis and then just the v. neg sync. I image didn't change much with either of them, however I was able to get the image to stabilize very briefly when just the v. neg sync was attached. Weird.
I'm still clueless and very lost. I might try replacing the IC501. Bob Roberts told me that "96% of the time it is just mis-wiring the sync or bad connections, 3% the IC HA11244 & 1% one of the 4 sync amps 2SC1815 being bad." So I don't know what to do.
Suggestions?
Suggestions?
