I have a Frogger that is having a small sound issue. When the game is first plugged in, the sounds all seem to work properly. After a few minutes, some of the sounds are no longer correct. For example, the credit sound works fine when first plugged in but after about 10 minutes, when you add a credit it makes this weird high pitched beep. Also there is an occasional random sound that is produced that will continue after the game is over. I was going to replace the AY-3-8910. The description says "programmable". That does not mean that it has to be programmed prior to installation does it? Im guessing no but wanted to make sure.
