But the bottom right corner is warped a little. Is this just a simple adjustment, or will a cap kit fix this do you think?
Thanks,
Steve
A cap kit will make that better. if it is still a little noticeable, then make C517 and C518 BOTH 220uF 16v caps. The kit has one of them as a 100uF 16v, but making them both 220Uf 16v will help square up the picture.
BTW - if you were going to all the trouble of replacing the flyback and HOT, you should have done a cap kit at the same time while you had it out...
I'll do the cap kit Sunday. I'm not super fast at doing them.
