Frogger Screen Glitches when bumped - Video
Looks like you have a G07 monitor. Try tweaking the g07 horizontal frequency pot and that should fix your problem.
I'd check the interlock switch(es) and back door first. Looks like it's rebooting when you hit the cab.
It does look like it may have rebooted when he slammed the coin door, Does Frogger have a coin door slam switch? But the last time he bumped the side of the cabinet the Frogger music continued playing but the pic was scrambled so I still think it's a monitor problem.
I just looked at my Frogger and it dose not have a slam switch.
Don't think it has a slam switch, but there's a interlock on the back door of the last one I worked on, door was a bit loose and would reboot when you jostled it.
I would start looking at the cable harness's edge connector.
I have spent an evening just repining an arcade machine to prevent odd problems like this from happening.
This was it! Thank you for the simple fix.
I wouldn't have connected the bumping the cabinet screen scramble to this H.Freq problem.
Awesome!
THANKS
