Frogger problem
Taco
Spokane, Washington
Picked up a cheap frogger that plays fine for the first two levels, after that it kills you and game is over.I reseated all the roms with no change.Anyone have any ideas?
Hmm, do you have a rom burner that you can use to verify all the roms. I have fixed several frogger boards and several had eproms with bit rot and had to be replaced. Symptoms were similar to what your getting. Usually they would run fine in attract mode but reset when you pressed start button. Just a guess but easy enough to check if you have a burner. Also, I assume you have verified your voltages?
Is this a two board set or single board?
I don't have a rom burner or even know anyone with one.I haven't checked the votages yet I'll do that later today.It's a video board with an audio board on top I believe.Does anyone sell replacement roms or should I just find a tested board?
I have 2 spare working frogger boards.
If you going to cax, I can take a frogger cocktail to the show. We could test your board in my cab..
