Frogger PCB sound problems...
I believe frogger had an external pot like the mk1s check for that, the sound pot might have a loose connection or the pot is junked up or I even seen them broken... also I seen them boards hacked with an onboard pot, also if you have a spare board pop in the sound chip it's right up against the 608 609 610 chips I can't think of it right now, anyway give them a look over.
Pull and verify the eproms on the top board. I have seen many, many frogger boards with bad eproms. Seems like most of them had Fujistu brand roms and apparently they have a high failure rate as I have seen bad ones on other boards also. Sure other brands fail too but these seem to fail at a much higher rate.
Dont have anything to verify the roms with. The game is likely being parted. Do you want this boardset before I put it up in the FS section?
