Frogger monitor removal
SaminVA
Hampton, Virginia
I have a dedicated Frogger with a K 4600 monitor that needs a cap kit. I was going to remove just the boards and flyback but this is the old type that doesn't have the removable bottom tray and you cant remove the screws because the monitor is setting on a piece of wood so I have to remove the hole monitor. I removed the back door and the upper wood back and removed the cardboard bezel. Now do I need someone to hold the monitor wile I take out the 6 bolts holding it to the wood frame or can I lay the cabinet on it's side or can you slide the monitor out attached to the wood frame? I took the 4 screws out of the metal L brackets at the top but the wood is attached to the front of the cabinet too. Which way do you do it.
The wood is basically an L shape with the part around the tube attached to the part under the chassis. You remove the bolts holding the tip in place, then remove the bolts (I can see one on each side in your pic) holding the bottom piece in place. Then you should be able to lift it up a bit and pull it right out the back...
So the whole wood L bracket comes out in one piece with the monitor still bolted to it. Guess I need to remove the screws in the front piece of wood.
Thanks Mod
