Frogger monitor problem! please help
noname707
Santa rosa, California
I am having a problem with my monitor in my Frogger machine.
the far right 1" or 2" of my screen is all distorted or tilted if you will. the rest of the screen look great. what could be causing this? and can I fix it? thanks for any light you can shed on this issue.
You need to first identify which chassis type you have:
http://arcadecontrols.com/BBBB/monitor.html
If you can post a pic, that's even more helpful.
But it sounds like you need to adjust your horizontal hold/freq pot. If the caps on the chassis are failing, then you may not be able to adjust it out completely until they get replaced (and possibly some other parts)...
