Frogger monitor 20" Nanao mc-2000-r swap to g07
78whiteorbs
North Carolina
Got a dead 20" Nanao mc-2000-r in my frogger which is playing blind.
Have a tested working g07. I know they used a few different monitors in froggers and g07 was one.
Question is will it fit if I don't have a vertical g07 frame or will it stick out the back?
It will definitely stick out the back. I have a horizontal G07 in my frogger right now and I can't put the door on.... I thought about cutting a hole and 3D printing a Gorf style neck protector since Gorf's monitor sticks out the back from the factory and they use that cover. Or just using one of my many many Gorf neck protectors.
Was thinking that it might
The horizontal frames are just so much more abundant, and it seems like we both are in the same boat. I had to do quite a bit of cabinet modification to mine to get that thing in there. The original uses that goofy sliding board with the monitor bolted straight to it. So I made some changes.
