Frogger / Matsushita Screen Flip
Superully
Lauda, Baden-Wuerttemberg, Germany
i had to install a replacement monitor in my frogger and the only working one i had lying around was a matsushita tm202g (i know, not the most realiable of monitors). it's working fine, but unfortunately the picture is upside down. i cannot rotate the monitor, because the anode cap - flyback wire is not long enough (i had to remove the chassis from the monitor frame to make it fit into the cabinet).
so i need to figure out one of the two solutions:
- flip the screen through a switch on the frogger pcb (which i think is not possible)
- flip the screen through some plug / setting on the monitor chassis
or is it possible to extend that anode cap - flyback wire?
any help is appreciated, if you need pics of the setup just let me know!
