You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
I'm basically a noob when it comes to these games but can do basic electric testing and resetting chips and other things. Definitely
not super technical with them though, but learning what I can. I've been sitting on this Frogger for a while and thought it's time to get it going. Plugged in it doesn't do anything. Not even a hum. I checked the 2 fuses at the bottom plus the fuse on the back door switch. They show good. Maybe it's the switch itself-I'll check that next. I don't see a power switch on the back door area,,,is there one like many other games? Or was it simply plug it in or unplug it? Any guides out there or descent manuals? I figured I'd test the power supply, then see if the board is getting power etc. Any wisdom that can be shared is greatly appreciated. I included a picture too- was hoping everything looks original and in place. Noticed some plugs near the bottom center with nothing plugged into them. Also does this game typically have a power door switch at the coin door? I didn't see one.
