Frogger joystick size
jimbodeanny
What size of red ball joystick was originally used in Frogger? The joystick that was in the control panel when I got this Frogger was a tall, thick, red-ball leaf joystick. It's thicker and larger than the one in my Ms. Pacman. I'm trying to determine if that's the correct one or if I should swap it out with the thinner kind.
-Jim
Mine is the thin red wico.
Definitely smaller than a Pac-Man as a normal wico grommet wouldn't work to fix how loose mine is.
