Spyridon
You know, I've heard you call your arcade that many times, but you've never explained what it meant. Is it:
but I like yours better
Oh My God - Where's The Freaking Booze - Bring Quick!
Oh Man, Garage? Where's The Full Basement? (Bring Quarters)
If you're going to make up words, then you at least need to let us know what they mean. Similarly, define "Ninty".
-Ian
-Ian
-Ian
Or, how easy would it be to remove the front wood panel from another cab? Anyone ever do that?![]()
I was able to remove the front panels. Wasn't too bad. Six screws then I hammered it off and loose of the staples. Much better!![]()
good to know! will have to do the exact same thing on mine - with one difference: the entire front panel has been hacked (bally coin door fitted in), so i will need to cut a replacement panel. would be much easier if i could have one of yours, but unfortunately there's an entire ocean between our two locations![]()
Looking good. Everyone should have a frogger.
Yes. Actually, I think it's good that he has several. I mean, you need extra lives - how else are you going to be able to successfully push the game across a busy street? That way, when one game gets hit by a semi, you've got a couple more tries.
-Ian
