Frogger harness / edge connector
roburt
Dayton, Ohio
Can anyone help me out. I'm having assorted problems with my frogger. It's an early one with the 44 pin connector. Does anyone have a pinout for this? The ones I'm finding online (like mikesarcade) have alot of m/t spaces on their pinout chart. Also, can anyone snap me a photo of their edge connector. Mine's been worked on & I think that's what's causing my problems. Thanks!
I can't read the number on your PCB - Little white sticker in the middle just above the edge connector. If you can send me that, I should be able to point in the right direction/page of the manual. Just had to redo mine a month ago but it is a different PCB so I need the number to make sure you get the right page.
Look at the pinout for a pacman, its mostly the same. I think there might be a couple pins that are different but they are not power so dont worry about burning anything up.
Thanks for the support guys! I'm sorry I didn't update. This post was from February '011. I have since got both of my Frogger pcb problems corrected. Turns out on the 44pin, that it had been hacked a bit. I had a broken wire in the harness itself and some crappy solder work on the connector from the previous owner (who was a tech for a living!). Still have some monitor problems to work out, but all will be well.
Thanks again.
