Frogger G07 Sync
roburt
Dayton, Ohio
Again...with the frogger problems! I have another frogger project. I am installing a G07 CBO into a 44 pin frogger cab. I do not have a pin out for the pcb. How should this be wired. It has no monitor in it at this time, so I'm taking a stab in the dark. Any suggestions or color coding I should go by? Any and all advise will be properly appreciated! Thanks!
Thanks Modessitt. Have you done this before and is there anything I should look out for? I believe I have to up the voltage from the power supply for the G07. The power supply in this one is original. I'm not sure what monitor type of monitor was in it before. Thanks for you link!
