Frogger Color Problems
pistolpete
Owasso, Oklahoma
Electrahome G07.
Started out, no picture, no sound, glowing tube.
Replaced 2 main fuses, 1 missing, 1 burned out. - sound, no picture.
Seated loose neckboard (really loose) and I get a picture with bad colors. (See attached).
I pushed the brown wire on the left in the other pic onto its pin (was loose), turned it back on, and all was good. Colors were correct, played for a while.
a few days later, I turn it on, all is good and after a few minutes I'm back to the rather red looking picture you see below all the time, even after a restart.
I tried unplugging, reconnecting the connections to the monitor board, check for any loose connections, etc. and no joy.
I've read the stickies but can't seem to narrow this one down.
I also caught it on film flickering once between red and blue background and attached that one here, too.
Any guidance would be appreciated.
Thanks!
