Frogger Cocktail owners-
78whiteorbs
North Carolina
Where does the monitor chassis mount?
This game came to me playing blind but the chassis was in a basket. Got the chassis sorted but never saw how it mounted as it was already removed.
Also I've notice there seems to be 2 different sega versions (more actually if you count the Taito with the vertical joystick)
1 seems to have the 19in and older art
And other is smaller (13/14in?) with newer art
Mine is the 19in.
Can't figure this one .... I *think* I could fab a bracket for the chassis in front of the pcb area and then the adjustments would be accessible from the top .
The monitor that belongs in a sega cocktail table (frogger, zaxxon) is a Nanao MC-2000-s 20" monitor it has like a metal wire frame and fits the cocktail snugly, froggers came out with 2 size monitors the 13" is the older table, the chassis you are showing doesn't go in that table it was replaced at one time as the nanao are not an easy monitor to fix but have great pictures
Saw there was switchable plug for 100v plug on the power supply as well as a switch that toggles between 110v /120v.
This 19inch tube fits but now I wonder if the tube matches the chassis. Appears to the yoke wires etc all match up.
So guess could be a g07 dropped right in and someone was about to install the chassis and that's were there work stopped and mine began. So if I wanna run the g07 gonna need 110v from the iso transformer.
So weird because looked like this tube had frogger burn but maybe I am wrong and mistaken. Check the burn-
Also weird was the g07 chassis that was with it had a plug for the power which I don't see often on this model and it is stock that way this board is clean and new lookin as I've seen . Seemed to go with the pluggin on the power supply see-
So my next question is this:
Any harm in putting that go7 in there? ,
I can make a wood bracket to mount the chassis too easy enough, just wondering if it was closer to the anode cup side if that'd cause any issue because of proximity electrically.
