I have a Frisky Tom pcb that when powered up says RAM OK, ROM OK, but then keeps repeating this screen:
Question, this transformer is 6.0v, and we need 6.3v, is the .3v less difference going to make a difference?
It's simple.This transformer has two primary windings and two secondary ones.
So, since you are in USA, you have to use the black and red wire for the 115V input.
As for output, you have two choices according to the power absorption if more or less 700mA.
Since we don't know how much current draw the circuit that requires 6.3VAC, I'd go safe and chose the 1500mA outputs (blue+blue)
Ok, I already hooked up one set of black and red to the 115v input.
Now, as for the blue and blue. How do I hook those up to the pcb? connect them together into one line and to the 6.3v edge pin on the connector?
Ok, hooked up the transformer, and tested the two blue wires. I am getting 6.5v AC, shouldnt it be 6.3-6.5v DC to the pcb?
Red lead to one blue wire, and black lead to the other blue wire, to test on the multi-meter, correct?
