Freebie: Empty Megatouch Upright cab (near Philadelphia PA)
orion3311
Donor 2013
Blue Bell, Pennsylvania
I have an empty Megatouch upright cab up for grabs, near Philadelphia PA. This is NOT the cabaret, its the standard upright that has the slightly larger top. (Kind of a....mushroom....shape...use your imagination...).
ANYWAY, it was an older Megatouch series and I need the parts from this, so its basically empty. If you need a monitor or coin door we can talk.
Cab is pretty solid, only downside is the outer sides are pretty swollen. You could leave it as is and fix up the t-molding, or just remove those sides and replace em. Its kinda like space invaders where the sides are layered - the inside layer looks fine.
Possible Uses: If you have a spare touch screen you could use this as a jukebox, or even better, mount some gun holsters and start buttons to the front and use it as a shooter cab. I'm considering the latter but I'm REAAALY out of room. PM if interested!
Here's a pic of what it looks like - this is NOT the actual cab:
