FREE - Parts: Free Sega Nascar Projection Monitor Clio MI
denny427
Clio, Michigan
Rating - 0%
0   0   0
Free to a good home, a Sega Nascar Projection Monitor. The monitor worked but needs help with sync and color issues. Exterior looks very good, with a couple wood defects on the back side. It is from a deluxe version that I converted to a 46" LCD, so I spent zero time trying to fix the original projection unit. If anyone can use it, I certainly prefer that you are local enough to arrange pick up at my home/shop in Clio, Michigan. If after two weeks there are no takers, I would consider dis-assembly and shipping parts at cost. Just hate to trash it if someone can use it. The attachments include a closeup of the Model No. tag.
mitsubishi projection parts
Hello, I would be interested in buying the crt projection bulb set from you. I am in michigan also about 45 min away
projection monitor
mja2500 is picking the monitor up tomorrow. I am glad to have the space back and very happy not to scrap the monitor. Thank you Mark!!
